30 amp solar generator
Can I input from a 30 amp solar generator into my Fox Hub? The generator inlet is a 50 but I can use an adapter.
Also, does the generator inlet charge my Fox batteries or power the whole house?
Re: 30 amp solar generator
I am wanting to use my EcoFlow batteries to charge my Fox batteries through its 30 amp connector. The provider is not sure if that will work or not. The big question is whether the generator inlet to the Fox Hub is charging the batteries or running the house. (I think the first, but the provider is not sure). The provider is concerned that the 30 amp input will damage the inverter. Can anyone tell me for sure? If it is just recharging the batteries, it should not affect anything.
