Any idea why this is happening or it is a temporary glitch in the system. My installer says he is unable to logt on as well. It has been working well up to now since connection last week.
Home Assistant with modbus is the way forward. Completely avoids having to use the Foxcloud infrastructure.maoh1 wrote: ↑Mon Apr 24, 2023 8:43 am Again down wtf. Just bought and had installed this system 4 days ago and 2 days it had not worked properly. In the morning app worked well, now is showing what battery offline and 0kw.
Do anyone know what I can use instead of this cloud? I can set it up, but I wanna know what to install
Try not to worry. There are other posts on these forums and on the Fox Facebook groups from lots of other users all with the same issues you’re describing. And I’m one of them. The consensus is that Fox are doing work on their end and the result is both the Fox and Energy Stats apps are down. In the meantime as long as there are no error messages on the inverter itself, your system will be working as normal.Annscullamus wrote: ↑Wed Oct 11, 2023 8:14 pm I have this problem too. The app shows error 412000 ‘query data’ not responding’ or something like that. I have deleted and re downloaded the Energy stats app and the Foxess own app. Both are just blank. I have no idea why, and as a pensioner with No technical knowledge where do I go for help. My system was fitted on Aug 11 2023 so I am quite new, but the apps have worked perfectly since that date. Help !
Hi, would you be able to screen shot the screens you are talking about and post them below so we can see what you are seeing.JohnG wrote: ↑Mon Jul 01, 2024 1:07 pm Hello
I'm new to this forum after having had solar panels installed on my roof recently and downloading the app to my laptop as I don't have a smartphone.
The app was working perfectly well until a couple of days ago since when the Live Status is showing all the energy going to Load Power and none to the Grid. This is clearly incorrect as confirmed by the bottom "Overview" line chart.
Any advice on what the problem is and how I might rectify it would be welcome. I'm not a tecchie by the way !!!
Thanks.
The inverter is solar only.Dave Foster wrote: ↑Mon Jul 01, 2024 1:17 pmHi, would you be able to screen shot the screens you are talking about and post them below so we can see what you are seeing.JohnG wrote: ↑Mon Jul 01, 2024 1:07 pm Hello
Thanks.
Off the top of my head, this is usually indicative of the CT clamp being installed the wrong way round or in the wrong place, but if you can post those images it will help diagnose it - if you could also say which inverter it is solar only (F/S series), Hybrid with batteries (H/KH series).
