I have a little "problem" with my Fox ESS H3 hybrid inverter, my ECS2900-2 and my automation via evcc (version 0.208.1).
With evcc I can set up a plan to charge my battery from the grid. I use a dynamic pricing so it would be nice to charge my battery when it's cheap when there is not enough sunlight / there will be not enough sunlight - winter is coming!
In the Fox ESS App I can turn on charging from the grid and it works. The battery will be charged with ~7.9 kW.
In my evcc App I can turn on charging from the grid but it will just charge the battery with 400W.
I would prefer the evcc app because it's easier to configure and faster.
The evcc app runs on a little raspberry pi and gets the data using a RS485 -> WLAN adapter (modbus). I can see all my data from the inverter, I can see the SOC, I can charge my EV without using the battery or just with electricity from my PV. So far I am very happy with it - but the "battery-grid-charging-problem" still annoys me.
I've asked the evcc community before - no solutions found. Everything should be configured correctly.
Thanks for your help.
Sunny greetings from Germany
McKeolegh
