ExportLimit
Posted: Wed Oct 26, 2022 10:25 pm
by EcoJones
Can someone please confirm what this inverter setting does.
"ExportLimit"
I assume it limits the amount of power that can go to the grid but does it also limit power that can be used in the house?
Re: ExportLimit
Posted: Thu Oct 27, 2022 6:58 pm
by Will
it's the concurrent limit for export (feedin) only not what that house can use. House can still use up to the inverters rating. It's only the power limit setting that restricts the inverts output to a fixed %.
Re: ExportLimit
Posted: Thu Oct 27, 2022 8:24 pm
by EcoJones
Thanks for confirming Will, that is what I thought it would do.
Out of interest do you know where I might be able to find some documentation on the inverter settings? The booklet that came with the inverter is quite limited, something a bit more advanced would be handy.
Re: ExportLimit
Posted: Sun Oct 30, 2022 5:10 pm
by Will
There isn't any documentation sadly but I did make a walk through settings video
Re: ExportLimit
Posted: Mon Oct 31, 2022 12:08 pm
by EcoJones
Thanks Will, that should come in handy.
