Inverter settings resetting by themselves
Posted: Mon Sep 15, 2025 2:53 pm
I have a KH10 inverter with an EQ4800-L9 battery stack. I have connected my inverter to my home assistant via the modbus integration, but I am having trouble getting settings to "stick". This is only happening for the "Export limit" setting at the moment, but when I use the "write registers" action to update the export limit to 0w it changes back almost immediately to the default of 5000w.
This has only started happening recently, in the last couple of days. For the last month that I've had my system it was working as intended, the setting was applying and staying active until I changed it. I have not changed anything within my automations. I asked my installer if they knew what could be going wrong and they have no idea, they said they don't have access to my system for updates, so it doesn't sound like it's a new firmware update or whatever.
I did a hard reset on my system today which fixed the issue for about 3 hours, but after that it just started happening again, changing the export limit over and over as my automations tried to fight with whatever is changing the setting back.
Can anybody help with this issue? I have no idea what could be causing it.
