Change Work Modes on Inverter?
Ched
Is there any way to change the work modes on the inverter via Home Assistant?
I am trying to see if there is a way to force charge during 'off peak' times and to force battery discharge to grid when the export tariff is high. At the moment I can see how to set force charge at certain times of the day via the FoxCloud app which is fine but I can't see any way to remotely set to discharge battery to grid at pre-set times. Is this possible?
Sadly not, the HA integrations are presently read only.
There is quite a bit of discussion about this being a requirement, so it may be possible in the future - some people have fitted switches to the CT clamp that reverse the flow which discharges batteries to the grid but it’s not recommended.
Ched
Dave Foster wrote: Sat Feb 18, 2023 4:40 pm Sadly not, the HA integrations are presently read only.
Thanks for that. Trying to find out the details of what things can do and what they can't is always a tricky thing, especially when you can't really play with them before purchase.
I read all the manuals and tried to work out what was possible before the install.
Only reason for forcing export is new Octopus tariff but it's not a big deal.
Thanks again.
It'll be interesting to see how this develops, the new Octopus Flux tariff relies heavily on either solar or battery export - I believe Foxess are very aware of the requirement, it's likely this could be a big selling feature in future, so lets keep our fingers crossed they develop a force discharge option :)
