I am currently force discharging my battery but there is only 1.x kw going into the grid and a current load of 3.x kw.
Is this screenshot correct i though the whole 5kw would be exporting
Thanks for your reply.Dave Foster wrote: ↑Tue Sep 09, 2025 8:29 am If you are Force Discharging at 5kW the discharge will be limited by the maximum power of your inverter (i’m assuming this is a 5kW inverter?) - the AC power is firstly used to power the house and any excess will go to export - if your house load is 3.21kW then the 1.91kW being exported is correct.
Can you post your scheduler settings so we can eliminate any errors.Bentleyfamily wrote: ↑Thu Sep 18, 2025 4:55 am Hey guys. I have a issue that is similar to this except that when I do my forced discharge, no discharge happens.
I have my parameters set correctly and triple checked 5000kw/h etc.
At night the house hold uses constant under 1kw/h of electricity but the battery only provides the electricity to the house and not to the grid at all even though it's set up to full discharge to 10%.
Has anyone else had this issue?
