Just introducing myself here, I've come from the FB group.
My Tech:
6kW of solar
6kW H1-6.0-E inverter
12 kWh cube
Zappi car charger
I also run a forum that looks at all kinds of modern tech.
Greetings
100% electric house / car
6kW PV
6kW H1 Inverter
24kWh Energy Cube
Zappi Car Charger
ASHP
Datahopa Tech Com
6kW PV
6kW H1 Inverter
24kWh Energy Cube
Zappi Car Charger
ASHP
Datahopa Tech Com
Welcome!
How are you finding the battery storage? I know the cube is a new product.
2 x KH Series Inverters
Hi Will, I've had the cube for nearly 3 months and so far I haven't had to use grid power once
Charge it every day from the PV, even cloudy days it's working great, OK it does have a couple of quirks that I'm working round, the sudden drop of SOC at night and the lower than expected kWh output but it's still a nice piece of kit.
I'm going to upgrade it to 20kWh once the slaves come back in stock, I have them pre-ordered.
6kW PV
6kW H1 Inverter
24kWh Energy Cube
Zappi Car Charger
ASHP
Datahopa Tech Com
6kW PV
6kW H1 Inverter
24kWh Energy Cube
Zappi Car Charger
ASHP
Datahopa Tech Com
good idea, batteries will be a serious money saver as the price of grid power continues to increase.
Reading the install manual it’s a simply case of lifting it into place under the master and updating the masters dip switch by one place. Should be a 30 second job.
Oh yeah not worried about installing, more dodgy suppliers and inflated prices. Although I can't help but feel a design flaw here, surely having the master as the base would make more sense for a few reasons.
- No disturbing of fixed cabling
- No need to lift heavy equipment twice
- Only need to manufacture the master to be able to 'accept feet'
I don't believe the cover needs to be removed on the cube, it's simply slots ontop of each other, so powerdown, pull the top master off the top, place the new slave on top of the existing slave and pop the master back on top of the new slave.
No, I know the cover doesn't need removing. I was suggesting a potentially better design whereby slaves are on top of the master.
With the current design the heavy master has to be removed (along with cabling potentially). Then you need to put that somewhere whilst you add a slave before putting it back on top.
It just seems inefficient
oh I see, yes having the master at the bottom would make more sense. I see your point!
I'm going to be adding 2 more slaves to my cube, I thinks it's pretty easy to do but I also belive there is a right and wrong way of doing it or at least a correct way of doing it. Will start a thread about this in the new hardware section.
6kW PV
6kW H1 Inverter
24kWh Energy Cube
Zappi Car Charger
ASHP
Datahopa Tech Com
6kW PV
6kW H1 Inverter
24kWh Energy Cube
Zappi Car Charger
ASHP
Datahopa Tech Com
awesome stuff, thanks.
